Change Part Name in Configurable Parts
ethan_doak1ethan_doak1 Member Posts: 11 PRO
I'd absolutely love the ability for Configurable parts to be able to change the name of a part. Our part number system includes the length of a part (for ease of use later on) and it would be sweet to be able to integrate the configuration function into our libraries and retain our part number system.
  • lougallolougallo Member, Moderator, Onshape Employees, Developers, csevp, pcbaevp Posts: 2,014
    edited April 2020
    @ethan_doak1 You can do this today for PARTS in the Part properties area of Configurations however I think this is more about using dimensions and other variables into the part name correct?
    If you want it to do this with a wildcard value from a config variable, that is a different request I can add this to.
  • alnisalnis Member, Developers Posts: 452 EDU
    @ethan_doak1 something like this? It automatically names the part as it is found in the goBILDA online catalog and sets its SKU/part number, plus sets the Title 1 property to the appropriate catalog URL (all procedurally through the Property explorer FeatureScript)
  • PrachiPrachi Member, OS Professional Posts: 262 ✭✭✭
    don't forget to add your own vote.
