total OnShape newbie - need help drawing on imported assemblies
I am very new to OnShape, having only started using it in the middle of January, and even then, in limited fashion. I know nothing about design nor do I know anything about anything CAD related, so this was my very first foray into both. As for what I have managed to learn, well, I don't know how to do much other than create very rudimentary sketches and a even less with respect to extrusion. I know nothing about creating assemblies, let alone anything about best practices.
I have an assignment where I need to create a wall-climbing robot, which in itself is a monumental task, without being stifled with my extremely limited knowledge of designing parts in OnShape.
What I've done, so far, is imported an assembly of a the Tamiya Tracked Chassis. Whoever, did work on this did a brilliant job. Now, what I was hoping and trying to do was create some drawings of additional components that I needed 3D printed. And this is where I have hit a 100-foot wall. While, I was able to import the file(s) and have the assembly sitting in my online personal folder, but nothing is doing what I was hoping it would do.
I cannot draw anything. I can't copy and paste. I can't move anything between assemblies (is that even a thing that can be done?). I'm, quite frankly completely stuck, and given my limited knowledge, I am not sure if I even know how to ask questions to get useful feedback or give any pertinent information to help me in my predicament.
I am completely stuck, so I would really appreciate any and all help, keeping in mind that I will probably not know what you're talking about if it requires any knowledge beyond what I have.
If you got time today let me know and I'll help get you moving.
Sounds like there is too much explaining needed to post it all in a thread
https://forum.onshape.com/discussion/13414/onshape-newbie-needs-help-to-create-a-new-sketch-on-an-imported-assembly#latest
You should start by impoting everything into an assembly.
From there you can position everything where you want it using mates.
Then you can start sketching your parts in a partstudio.
Also screws and other fasteners can be found in the assembly->insert->standard content
So hit the + and create a new assembly
Now on the top left od the screen is a button called insert. Or just press i
Now you can pick what you want in the assembly.
Make sure you are inserting assmeblies when choosing brushless motor and propeller
if you are still referring to the delete feature on you tree then yes. Removing the delete feature or unselecting the part in the delete feature will restore it.
if you are are referring to anything else they also yes. But you will need to open the versions and history, then find where you deleted your part. then restore it there.
