opBoolean.SUBTRACTION not working?
Federico_Casarini
                    Member Posts: 9 PRO
                    Hello! I am trying to create a quick feature script to engrave a text onto an existing object. This is the code I am using:
                        annotation { "Feature Type Name" : "Tag" }
export const Tag = defineFeature(function(context is Context, id is Id, definition is map)
    precondition
    annotation { "Name" : "Location and Orientation", "Filter" : BodyType.MATE_CONNECTOR, "MaxNumberOfPicks" : 1 }
    definition.direction is Query;
    annotation { "Name" : "Name", "Default" : "Name" }
    definition.myString is string;
    annotation { "Name" : "Size[mm]:" }
    isReal(definition.textsize, TAG_BOUNDS);
    var sketch_tag = newSketchOnPlane(context, id + "sketch11", {
            "sketchPlane" : plane(WORLD_COORD_SYSTEM)
    skText(sketch_tag, "text1", {
            "text" : definition.myString,
            "construction": true,
            "fontName" : "OpenSans-Regular.ttf",
            "firstCorner" : vector(1,0.1) * millimeter ,
            "secondCorner" : vector(0.25,definition.textsize) * millimeter
    skSolve(sketch_tag);
            extrude(context, id + "extrude21", {
            "entities" : qSketchRegion(id + "sketch11",true),
            "endBound" : BoundingType.BLIND,
            "depth" : -0.5 * millimeter
   //delete the sketch
opDeleteBodies(context, id + "deleteBodies", { "entities" : qCreatedBy(id + "sketch11") });
    var dir = definition.direction;
    var direction = evMateConnector(context, { "mateConnector" : dir });
    var start = direction.origin;  // xyz
    const moveFrom = coordSystem(vector(0, 0, 0) * millimeter, vector(1, 0, 0), vector(0, 0, 1));
    const moveTo = coordSystem( start, direction.xAxis, direction.zAxis );  // (origin * units, xAxis, zAxis)
    opTransform(context, id + "transform1", {
            "bodies" : qCreatedBy(id + "extrude21", EntityType.BODY),
            "transform" : toWorld(moveTo) * fromWorld(moveFrom)
    var target = qSubtraction(qBodyType(qEverything(EntityType.BODY), BodyType.SOLID), qCreatedBy(id + "extrude21", EntityType.BODY));
    opBoolean(context, id + "boolean21", {
             "tools" : qBodyType(qCreatedBy(id + "extrude21", EntityType.BODY), BodyType.SOLID),
             "target" :target,
             "operationType" : BooleanOperationType.SUBTRACTION,
             "keepTools": false
    debug(context, target);
    debug(context, qBodyType(qCreatedBy(id + "extrude21", EntityType.BODY), BodyType.SOLID));
The idea is to create a sketch on the top plane, extrude it, move it onto the selected plane through the mate connector and subtract the text from the original solid. Unfortunately, when I run the code, I get a "cannot resolve entities" error. The tools and target are intersecting each other.
I also added a debug line to check if I was selecting the right solids and seems correct.
Can anyone help me with this?
Thanks!
Fed
Thanks!
Fed
Jake_Rosenfeld
                    Hi @Federico_Casarini
When posting code, it will be easier to read if it is formatted. Please hit this button:
Which will create a code box that you can then paste your code into.
My suspicion is that your code is not working because opBoolean takes "targets" not "target".
Additionally, instead of sketching on the top plane and transforming, just call:var sketch_tag = newSketchOnPlane(context, id + "sketch11", { "sketchPlane" : plane(evMateConnector(context, { "mateConnector" : definition.direction })) });to position your sketch in the correct place from the beginning.Jake Rosenfeld - Modeling Team5 -
Jake_Rosenfeld
Yup! The definition map is not checked by the language itself. The "Cannot resolve entities" failure you are seeing is actually because at runtime the internal engine looks for "targets" sees that it is `undefined` and reports back that it could not resolve any entities. It would be good if this error was a little more specific, I will look into it.Jake Rosenfeld - Modeling Team5
var sketch_tag = newSketchOnPlane(context, id + "sketch11", { "sketchPlane" : plane(evMateConnector(context, { "mateConnector" : definition.direction })) });to position your sketch in the correct place from the beginning.You are absolutely right, that worked! I guess that anything that is inside the "quotes" doesn't generate an error in the editor.
Thanks a lot!
Fed
Thanks for all you help, super appreciated. You guys are doing a great job!
Fed
