How do I get a fillet on a flange?
yvogoetteyvogoette Member Posts: 2
Hello
Is there a possibility to set a fillet for the edge, which is formed by cutting the flange to size?
Best Yvo
  • StephenGStephenG Member Posts: 384 ✭✭✭
    You should be able to do it.
    Following is a sheetmetal part with an extrude that cuts a couple of flanges and I was able to fillet an edge.
    Note: The fillet was added after "finishing" the sheet metal part.
  • john_mcclaryjohn_mcclary Member, Developers Posts: 4,059 PRO
    Fillet and chamfer can be limited sometimes.
    I think this is one of those cases.
    You will need to sketch a corner and extrude cut it, or like stephen said, finish sheet metal first.
    Unfortunatly the fillet won't show up on the flat pattern if you finish sheet-metal so I tend  to use the sketch/exturude->remove method
