external refs missing, but not showing me where this is happening.
![RyanAvery](https://profiles.onshape.com/3b5277257cdfe76321c8f5d764b3566a08fda7666f19b00ca8318e902510973c.png)
![Image: https://i.snipboard.io/uAiYel.jpg](https://i.snipboard.io/uAiYel.jpg)
See if that helps.
You can see the leader lines slightly where they would be showing the constraint icon.
The background color looks a little beige.
Do you have a custom CSS running?
Did you accidentally replace the icon reference for the constraints when injecting your CSS? Is that even possible?
You can tell that I can still see errors even though I'm using a dark mode for my browser, so the original post does show what I think may have been an error (i.e. erroneously not showing errors). Oh well, not a huge deal.
They likely broke if the parent sketch or object gets a new internal ID for those edges.
If you are seeing Red constraints and the geometry is correct. These may just be extras that are over defining. They may not be needed at all.
Try deleting them and see if anything turns blue.
If the lines turn blue add new coincident constraints to the new geometry.
By external I mean anything referenced outside of the current sketch.
So a normal rectangle face, if you Use that face you get 4 lines with 8 external constraints. Which means 8 places that could break if earlier geometry changes.
Or
Draw a rectangle locally and constrain the two corner points to the existing geometry. This way you only need to worry about the 2 corners breaking your sketch.
I'm just saying try not to make that a habit for simple shapes. Save it for the complex stuff that would take longer to draw from scratch that it would be to fix a mess of USE constraints for the hand full of times you may change the previous geometry.
For example the profile of an extruded aluminum bar, or the walls of a maze (top view). It would normally be worth it to delete and re-use the faces then fix the couple of broken features down the tree than to fully re-sketch everything in these cases. But a simple square and circle you could sketch is basically the same time as selecting your USE edges.
