How can I change the units of measure to nanometers?
monroe_weber_shirkmonroe_weber_shirk Member Posts: 99 EDU
I can't find any options for editing the available units. I'd like to create drawings of clay particles and I'd like the measurements to be correct.
  • monroe_weber_shirkmonroe_weber_shirk Member Posts: 99 EDU
    I tried entering 100 nm in the dimension of a nanoparticle and Onshape claims it is an invalid entry.
    This does suggest that Parasolid does its modeling using quantities that have dimensions instead of using a dimensionless modeling framework. Dimensionless modeling would have made it possible for the same modeling Kernel to handle any dimension with the limitation that within any model the range of dimensions would be limited to some maximum factor.
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,864
    Correct - Parasolid has an absolute measurement system - 1 micron to 1km
