How can I change the units of measure to nanometers?
monroe_weber_shirk
Member Posts: 96 EDU
in Drawings
I can't find any options for editing the available units. I'd like to create drawings of clay particles and I'd like the measurements to be correct.
OptionsMBartlett21 Member, OS Professional, Developers Posts: 2,034 EDU@monroe_weber_shirk
Onshape's modelling kernel, Parasolid, does not work very well with tiny measurements (I think its smallest available measurement is 0.001 mm or 1 um). This means that you will probably have to draw your model as a scaled version.5 -
Optionselif Onshape Employees Posts: 50Sorry to negate Neil, but Parasolid is in fact dimensionless. We currently take it so that 1 = 1 meter. nm as a unit is currently not supported as it falls into modeling tolerances.
I know that we are internally tracking an improvement request that would allow modeling on a smaller scale. Please check in Improvement Requests and vote or create one to collect votes from the community.Team Lead, Part Studios6
