Add mate connectors to more than two parts
francois_carlettofrancois_carletto Member Posts: 5 ✭✭
edited April 2020 in Community Support
Dear team, I would try to create a single drawing for all parts of a structure assembly. To do that i create new assembly with part all on a flat surface using the planar mate feature. Is there anay way to apply planar mate to more than two parts? Imagine : Clic on planar mate and clic on all part one after other and the all fall on the same surface.
See the pictures,
From assembled
To flat, observe the number of mate feature to do that... Why not only one?
Thanks for your answer.
  • romeograhamromeograham Member, csevp Posts: 694 PRO
    There are two Custom FeatureScripts that can help you:
    Mate Connector at Origin: this allows you to create a Mate Connector for each part at the origin....in a single feature: https://cad.onshape.com/documents/7a2aca223858e21747087f1c/v/d06b9de45deb6bba4211204a/e/36a983633c3f3c601fd50add
    Multi Mate Connector: allows a MC to be shared by several parts (might be closer to what you need): https://cad.onshape.com/documents/5d8da63844bedebe5cff72b1/v/cfcff754d7bed39f9aca3ea6/e/11dcab8f665add80b9aced0a
    Good luck!
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,806
    Planar mates should only be used in exceptional circumstances. It is a very “SolidWorks” way of creating assemblies. Use fastened mates with offsets (if required).
  • mahirmahir Member, Developers Posts: 1,314 ✭✭✭✭✭
    Sounds like @francois_carletto is talking about something like a multi-mate in SW - mating multiple parts to the same "ground" part. Instead of running the mate command 16 times with 32 clicks, half of which would be the same MC over and over, he'd rather have 16 clicks (or is it 17?)
  • john_mcclaryjohn_mcclary Member, Developers Posts: 3,942 PRO
    You already get to use 1/3 of the  mates you would otherwise use  in SW. What more do you want  <3:p
    jk jk
    But seriously, You can mate similar parts then copy/paste those parts to reduce the amount of clicks.
    For instance, mate your corner leg with the gussets, copy, paste 3 times, now you just effectively inserted 12 parts and 8 mates, but only added 2 mates by hand.
