TRIMMING MULTIPLE ENTITIES AT ONE TIME IN A SKETCH?
elliotelliot Member Posts: 3 EDU
Is there any solution?
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,933 image
    Use the Trim tool and click each segment to remove. There is no click and drag option like in SolidWorks.
  • elliotelliot Member Posts: 3 EDU
    A little disappointed without this tool for trimming multiple entities at the same time.
    IIt is less efficient to click each segment to remove .
    In many cases, you shouldn’t need to trim. Just select the areas when extruding.
