Mobile won't show dimensions
Hey everyone, I searched but didn't see anything on this topic. I'm using the mobile OnShape on my iPad Pro. But, one of the odd things is that I cannot manually define the dimensions. When I double tap for the context menu, I press "show dimensions" then nothing happens. The context menu disappears as expected, but no dimensions on anything show up.
Is there a step that I'm missing?
Thanks!
Thanks!
- add the dimension(s) manually
- save the sketch
- select all or part of the sketch
- two-finger tap to show the context menu, and select "show dimensions"
- if you want to edit any dimension, just double-tap on it, and the number pad will appear, allowing you to change the number.
Please let me know if that helps.bad habits with the use of Shapr3D which constantly shows the dimensions of the edited forms .
Sorry , I'm a beginner.
Best regards
LOL
Sorry I couldn’t get to it earlier but I’m busy doing a seismic retrofit down in my basement right now. But I snuck away for a few minutes to do these GIFs
@cris_cami
The first GIF has been slowed down a lot. In fact when I press or tap certain buttons, I have dramatically slowed down what I’m doing so you can clearly see what’s going on
The second GIF is played closer to realtime though that is even a little slower than how long it actually takes
SLO—MO
