Subassembly don't seem to update when update all
raphaël_fournier
Member Posts: 1 ✭
I did a modification into a subassembly :
When a I go into the assembly, i do update all and the modification of the sub assembly don't seem to be here with the update. I need to do "replace instance" to have the modifiation.
The sub is not pinned, so it's suppose to be up to date?
Thanks
Can you attach a link to your document here so that we can take a look? You can check here for the best way to do this.
Best,
Mike
