Defaulting to sketch tools.
neale_ashbyneale_ashby Member Posts: 2 EDU
When I start a new drawing it is set up with extruding tools and is a hassle to go back to sketch tools to start my drawing off.
How can I default back to sketch tools showing from the start? All help appreciated!
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,895
    It is not possible - you will have to press the Sketch button.
    Welcome to Onshape & the forum @neale_ashby!
    Learning the quick keys will help navigation a lot.  See 'Keyboard shortcuts'.
    for example to help on your question:
    shift s = open new sketch
    shift n = rename open sketch
    www.accuratepattern.com
  • john_mcclaryjohn_mcclary Member, Developers Posts: 3,962 PRO
    Shift+S will quickly get you into a sketch
