Why do I lose other dimensioning options when changing base dimension value in drawing
jason_atwood316jason_atwood316 Member Posts: 5
I am dimensioning a drawing. If I use the 'part value' then I have options to set other units, GDT, etc.
However if I change the dimension value resolution (in my example .714 -> .7140) then I lose all other options (they are all greyed out)
(FWIW I'm using the web app on Firefox)
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,926 image
    You should set the DP using the drop down to the right of the value. If you manually edit the value it is assuming you are overriding the value and it will set it as not to scale.
