how can I change the diameter of a solid
zahirzahir Member Posts: 6
    bruce_williamsbruce_williams Member, Developers Posts: 842 PRO
    @zahir
    Your question is too vague for us to help for sure. That said, changes are one of the strengths of parametric history based CAD.  Your image is of the Part Studio where the gear was designed. You may change the original sketch or Move face or Extrude Add or Remove to name a few ways.
    www.accuratepattern.com
    NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,370
    Looks like it was imported. You can use Transform/Scale or Move Face.
