Ability to delete mate connector of derived part
Hello, I'm still learing to model with OnShape, now composing some more complicated design with derived parts. I connect the part with others in new part studio through mate connector's transformations, but I do not want the original mate connectors coming from derived part in my new parts to be present, as I define new mate connectors elsewhere to be used in assembly. Is it possible to delete the prime connectors? This would be much less confusing when using the combined parts in assemblies with many mate connectors.
https://cad.onshape.com/documents/cfef86ed4f9635531599a973/v/5ee89fa6e9c437289bbc6f07/e/305f5ce7d2fdb46e12881f6f?
showReturnToWorkspaceLink=true
Otherwise, use normal derive, (hide the derive feature in the tree)
then use "Transform" -> "Copy in Place" to create a copy without the mate connector
then "Delete Part" to get rid of the original part with the mate connector
if your intention is to use the mate connectors in the part studio and just remove them "all" before sending to an assembly. I would put the copy in place at the end of the tree. Re-create any mate connectors you want to bring into the assembly, then delete the original part (to prevent accidental insertion into the assembly)
Another alternative would be through configurations.
In the original part studio set a configuration checkbox called "Assembly Mates Only" then set the suppression state of all your mate connectors you don't want to suppressed.
That will give you the best option for fine control
I'm not sure I follow you, here is what I did (see link above)
it sounds like you're going in circles with when you want mate connectors on or off.
It is a one way street. Once you remove it, it is gone. If you need it later on, then you can't remove it, only hide it.
