Excel spreadsheet
john_mcclary Member, Developers Posts: 3,959 PRO
No, there is no way to connect a spreadsheet to a drawing.
Link tab just lets you keep your google doc in an Onshape tab so it is easy to find/edit.
You will need to copy the information out of the spreadsheet and paste into a table in drawings.
5
If you want to add the excel file to a table in the drawing, then you can create a table and copy & paste each celd from Excel.
I think there are not and easy way to copy & paste all the table
Subscribed to Link Tab but how do I use it?
click the + sign on the bottom left corner of the screen, navigate to link tab
Follow the instructions here:
which basically says paste your URL here and click link
You may be asked to authenticate and give permission for Onshape and Google to connect.
By the way, this apparently dose not work with FireFox. So use Chrome or Edge
I thought it was possible insert the google sheet table straight away
this is a huge limit on drawing creation!
Please implement this,
optimum would be just copy and pasting my worksheets like other CAD do.
@Alex_Pitt, here is your post with the JSON exporter: https://forum.onshape.com/discussion/comment/92883#Comment_92883
Alternatively, Table - Custom Feature will let you take a CSV directly from an import which you can use in your drawing. Then if you update the imported file, the table will update.
