Custom Hole Feature
H_Wang
Member Posts: 20 ✭✭
The issue I found was for the tapped hole with counterbore, any modification to the bore sizes, it automatically change the hole to "custom" instead of "ISO", which is OK, but that removes the tapped thread. Tapped holes with counterbore is very useful if you are creating tapped hole for shoulder screws!
We need drill tip angle variables for standard and custom tooling.
