Can't get WebGL to work with FirePro M6100: any tips?
Hey all, I have access to an CAD laptop that has an AMD FirePro M6100 an an intel integraded HD Graphics 4600. I've tried a lot of things and can't get the WebGL to run using the FirePro, it only uses the Integrated GPU so Onshape's performance is less than it could be.
I've followed all the instructions on /check of course, for both chrome and firefox but neither work. Yes I have updated windows and AMD drivers to no avail.
Anyone else used this graphics card successfully?
Switch'm on; plug it in & heat it up.
You'll find you'll kill your battery in about 20 minutes and the fan will always be running; at least my dell latitude did that.
My little mac doesn't have the option; so I have to suffer. I do manage my projects and don't have much on the screen at any one time. I did look at the 13" mac pro and graphics were faster, but 3lbs vs 2lbs, I choose to manage my data vs. carrying that extra 1lb around. It's a choice.
On my MSI Stealth for example. it will throttle way down unless it is plugged in. So I always make sure it is always plugged in.
It will also throttle down the graphics if it gets too hot. So I make sure when I'm playing a game or have large assemblies open, that there is good air flow.
I haven't found a good/cheap air cooler that was quiet, so I made a custom fit one with quiet noctua fans, this keeps things ice cold and is barely a whisper.
Plugged In:
Unplugged: (seriously throttled... i've seen as low as 0.8ghz idle, and 2ghz or so max)
With Cooler:
Without Cooler:
All in all laptops can still be just as good as a desktop now.
I have a gigantic over detailed model I'm working on (igus logo on every chain link, full of fasteners, bunch of mcmaster-carr threaded components, 100ft long 6 layers tall)
and I can still benchmark pretty well in Onshape at the same time while taking the temperature readings above.
The air cooler is enough that the internal fans barely spun-up.
Edit: I was curious how much over detail was in the chain..
I'm actually surprised how well this laptop handles all of this without breaking a sweat... Without large assembly mode.
I used to slam on people for designing with a laptop. But this is preforming better than any quattro water-cooled desktop I've every had.
