loft issue with 3d spline
wei_xunwei_xun Member Posts: 9
Hi community,
I am trying to loft between a circle and an eclipse using a 3d spline as a guide. the feature wouldn't solve because "all guides should intersect each profile boundary". but i believe both ends of the guide do intersect the profiles.
I also notice that the center of the eclipse is a black dot while the center of the circle is white. does anyone know what the colors indicate?
https://cad.onshape.com/documents/ed7b6b4cb70ca79b5d89f3b6/w/5589382c744ebbe46d072e06/e/fc88f7c462e649d4b5dff23a
  • wei_xunwei_xun Member Posts: 9
    Thank you for the detailed response John! I went ahead and fixed the 2 issues your raised, but my result show a much thinner transition near the middle of the loft. How did you make yours more thick?
  • john_mcclaryjohn_mcclary Member, Developers Posts: 3,992 PRO
    edited June 2020
    I added more sections (those purple rings), 30 seemed to be about right
