How to get Midsurface for part?
ncmbhckplncmbhckpl Member Posts: 5
I want to get Middle surface (horizontal) for this part, but i couldnt.
I need help emergency.
Thank u.
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,848
    Do you mean the mid-surface of the entire part (for simulation)? Or the mid-plane (use midplane option in Plane feature)?
  • mahirmahir Member, Developers Posts: 1,315 ✭✭✭✭✭
    Midplane option of the plane feature will work fine if you just want to get a plane in between two planar surfaces. If you want a middle surface for the entire part you'll need to use Offset with a value equal to half the thickness.
  • ncmbhckplncmbhckpl Member Posts: 5
    Yes i mean mid-surface of the entire part for shell meshing, i tried Offset all part but left and right ears of part was drawn on different planes. So i could not.
    If it’s all one part you should be able to use offset surface. Can you share the URL?
    This part looks like it's sheet metal, but it's not really modeled like sheet metal, which makes shell meshing a bit sketchy. The material thickness varies anywhere from .77mm to 4.2mm. So if you wanted a true midsurface, you'd have to stitch together multiple Offset surfaces.
  • Paul_15Paul_15 Member Posts: 6 ✭✭
    How would the offset work if the opposing faces are not a constant distance apart?
  • EvanReeseEvanReese Member, Mentor Posts: 2,360 ✭✭✭✭✭
    edited April 2023
    I think if the part itself isn't an even thickness, it will have to get more manual. Here's an example with two thicknesses, and also one where the opposing faces are at an angle. These are generic examples of how to expand on the workflows above, but not how I'd actually model the parts below.
    For anything more complex (like compound curved surfaces that are different), then it's not something Onshape is set up for aside from just manually modeling the middle surface, but something like the Tween command in Rhino would do it. One could also make a custom onshape feature to approximate it, but that sounds pretty tough to me.
  • billy2billy2 Member, OS Professional, Mentor, Developers, User Group Leader Posts: 2,092 PRO
    Which FEA program are you using?
