How to access previously attended Instructor-led course recording?
brendan_romano_romano
Member Posts: 9 PRO
I attended Instructor-led course 2 years ago when first purchased the standard license.
I am having design questions, and I know the answer is in that course recording.
How do I access it?
Thanks!
How do I access it?
Thanks!
KatieHuffman
Member, Onshape Employees, Developers Posts: 194
@brendan_romano_romano
Bootcamp has evolved over time, and depending on when you took it changes how you may access the recordings.
If you attended it about 2 years ago, you should find a Completion: Onshape Bootcamp course on your Training Dashboard in the Learning Center. It might be under the Completed tab. From there you can navigate to the recordings under the Resources section, find your class dates, and links to the videos should be there.5
