Improvements to Onshape - June 24th, 2020
cody_armstrong
cody_armstrong Posts: 228 image
edited June 2020 in New in Onshape
We are excited to bring you our second update this month. This update focuses on new features and usability improvements in both assemblies and drawings. Let's dig in.
CAD IMPROVEMENTS
SHOW MATES MODE
You will find a new "Show Mates Mode" feature in the assembly toolbar. This new mode allows you to mouse over parts in the assembly and dynamically see the mates highlight.
https://onshape.wistia.com/medias/1s5t48xsaf
SHOW MATES IMPROVEMENT
Now, when right-clicking a subassembly and choosing the option to "Show mates" you will only see the mates that constrain the subassembly to the top-level. In the past, all the mates within the subassembly would also be shown.
LARGE ASSEMBLY PERFORMANCE IMPROVEMENTS
Improvements have been made to the assembly architecture in Onshape to improve performance of large assemblies. These improvements will result in faster load times and less memory consumption when working with large assemblies.
DRAFT ANALYSIS IMPROVEMENTS
Improvements have been made to the Draft Analysis feature to better illustrate positive and negative degrees of draft.
https://onshape.wistia.com/medias/b6xrngrycn
VIEW CUBE IMPROVEMENTS
Clicking the arrows around the view cube now rotates the model in 15 degree increments. Previously, each click rotated the model 45 degrees. You can also now hold down the "Shift" key when clicking the arrows around the view cube to make precise 5 degree movements as opposed to the default 15 degree movements. You can use the keyboard shortcut "Shift" + arrow keys to rotate in 5 degree increments. This can be especially useful when trying to get just the right angle for a Named view.
https://onshape.wistia.com/medias/pnjj0ovkhw
STANDARD CONTENT IMPROVEMENTS
ISO Standard 8734 Parallel Pins have been added to the library of Onshape Standard Content.
SHEETS FLYOUT IMPROVEMENTS
The Sheet Flyout in Onshape Drawings now displays Part Number, Version or Revision, and State of the sheet reference.
https://onshape.wistia.com/medias/9rzi5iy8p8
CREATE PROJECTED VIEW REFERENCING SECTION VIEW
You can now create a projected view that references a section view. The projected view is not sectioned.
SHOW SKETCH POINTS IN ONSHAPE DRAWINGS
You can now show sketch points in a drawing view in Onshape. Simply right-click a view with a sketch showing and you will see the option to "Show sketch points." You can also right-click the view and "Hide sketch points." You can control how the sketch points are displayed and their size in the Drawing properties flyout, under "Construction geometry."
CONDITIONAL VISIBILITY OF ARRAY PARAMETERS IN FEATURESCRIPT
You can now control the visibility of parameters within an array parameter with logic. This means it is now possible to create custom features with array parameters that are only shown to the user when certain conditions are met.
Remember: The updates listed here are now live for all users when creating new Documents and over the next few days these features will also be available in Documents created before the date of this update.
  • john_mcclary
    john_mcclary Posts: 4,095 PRO
    edited June 2020
    Sweet, show mates and show only assembly mates! Can't wait to see if this helps troubleshoot assblies. That was always a royal pain.
    Logical feature parameters, show sketch points in drawings.. Nice
  • Jolly
    Jolly Posts: 82 PRO
    Alright! Mate improvements. I use the show all mates, then find the top level mate I'm looking for, then "hide other mates" on a daily basis.  Looking forward to using this change. Also the Mate View Mode?  I'll use that everyday.
    Always happy to see more standard content to. Saves me from making my own and building own ISO/ANSI/... references.
    Great!
  • emagdalenaC2i
    emagdalenaC2i Posts: 867 ✭✭✭✭✭
    Thanks, this FeatureScript improvement looks great.
    Un saludo,
  • Cache_River_Mill
    Cache_River_Mill Posts: 225 PRO
    edited June 2020
    Fantastic! Thank you Onshape team!
    Could this new feature script ability allow one to make a feature where the suppression is controlled by logic? @cody_armstrong
  • William_Schlund
    William_Schlund Posts: 9 ✭✭
    I like the projected view from a x-sectioned view. I couldn't do that before and thought it was me :)
    Good Job!
  • Theo_R
    Theo_R Posts: 82 PRO
    Show mates &  Show mates mode, View Cube & Sheets Flyout are very helpful to us. Thank you!
  • bruce_williams
    bruce_williams Posts: 842 EDU
    And draft view improvements - excellent!
    www.accuratepattern.com
  • EvanReese
    EvanReese Posts: 3,056 PRO
    I was just daydreaming wistfully the other day about conditional visibility in Array parameters. Awesome!
  • konstantin_shiriazdanov
    konstantin_shiriazdanov Posts: 1,221 ✭✭✭✭✭
    edited June 2020
    Nice that you starting to pay attention to assemblies and mates. Hope on the farther progress in this, especially in mate regeneration stability for multilevel assemblies.
  • otaolafr
    otaolafr Posts: 113 EDU
    nice updates! Would love aligment in drawings (like in ppt, ilustrator, corel, etc) and also export a named view to other documents parts studio
  • BMcGaffey
    BMcGaffey Posts: 29 ✭✭
    Wow, great improvements with the Mate diagnosis tools. Also, sketch points in drawings!
  • emagdalenaC2i
    En este enlace podéis ver las Novedades de Onshape en español
    https://youtu.be/L4kKHP_CmZo
    Un saludo,
  • ken_dellach455
    ken_dellach455 Posts: 7 PRO
    All wonderful updates!!  Keep um comin'!  :)
  • Ed_McGuire
    Ed_McGuire Posts: 24 PRO
    Yes!  Thanks for the improved panning!
  • brucebartlett
    brucebartlett Posts: 2,148 PRO
    Awesome work! Been waiting for this one, show mates improvement will make working with assemblies much, much, easier. No longer will we have to do the time-consuming task of showing all then search sub assy to hide unwanted mates.
  • brucebartlett
    Yes super excited by the show mates. Works perfectly. THANKYOU. Just about every time I use assemblies I had wished for this.
    But... now I have another wish which I constantly look for and that is an assembly search tool.
  • Hans_Ole_Leirvik
    Hans_Ole_Leirvik Posts: 83 PRO
    Very good - thank you :)
  • don_williams909
    don_williams909 Posts: 148 PRO
    Some very nice improvements in this release.
    That said, the "View Cube" movement is better than it was, and somewhat okay... but not exactly what I was looking for when I asked for the ability to adjust the views in micro steps.
    It's limited to using the XYZ cube coordinate system to make the movements, as opposed to "screen" position.  For tweaking a view for exploded views, often times you really want to be able to tweak the angles to get a better view of the objects and the exploded parts, with a better perspective.  You can't do that with 5° increments of the XYZ coordinate system.  You need to be able to do it to the screen position.
  • NeilCooke
    NeilCooke Posts: 6,097 image
    @don_williams909 - I may be wrong, but it does look to me like it's rotating around the cube center (aka screen center). For exploded view rotation, I usually get it roughly where I want it on screen, then right-click an edge and select "Align view with vertical axis" to straighten it up.
  • don_williams909
    Yes, I know this, but I would like to be able to save some views that are precise rotations of existing views that I create.  You can't do that with this setup.
    See your pals at PTC/Creo...
