Loft gets twisted
doonidooni Member Posts: 5 ✭✭
edited June 2020 in Using Onshape
  • StephenGStephenG Member Posts: 383 ✭✭✭
    What you should do is split the circle into an equal number of segments with respect to the other loft profile; segment length matters. Also, use the match vertex option to control any twist that might be produced. The there are optional guide curves which can be used to further refine the shape of the loft.
  • steve_shubinsteve_shubin Member Posts: 1,116 ✭✭✭✭
  • doonidooni Member Posts: 5 ✭✭
    Thanks, i could manage it by splitting the round part apart. Looking good now.
  • EvanReeseEvanReese Member, Mentor Posts: 2,478 ✭✭✭✭✭
    If Steve's answer worked for you it helps people who come after you with the same problem if you "accept" his answer.
    This particular issue is something I'd love to see improved in Onshape. Other parametric modelers with surfacing have ways to modify the connecting points without splitting edges or curves, which is important (to me anyway).
    edited June 2020
    I’d vote for this improvement
    Well, i didn't figure out how to accept his answer. I can only flag, quote or vote.
    Hmm I think it may have something to do with the category selected when posting. If it was "discussion" then the option may not be there, but if it's "question" then you might see it. Not sure, but also not a big deal.
