Custom units? (specifically milliter)
thomas_aa
Member Posts: 19 ✭✭
I'm creating a silicone mold, and as a first step I want to convert the volume of my part to ml (milliters).
I have managed to get the volume in mm^3 by using the Measure Value feature script, but after that, I have not found a good way to express the number as milliliters (or liters for that matter). Is there any way to use liter-based volume units? Custom units?
The solutions I have right now is to use a string (
roundToPrecision(#silicone_volume / (1000 mm^3), 1) ~ "ml") or skip the unit and name the variable with a suffix.
john_mcclary
Member, Developers Posts: 4,050 PRO
Fluid units don't exist in Onshape. Your work around is likely all you can do.
You may want to create an improvement request5
