BTEC Level three engineering (2010 Spec) Unit 17 Solid and Surface Modal
Ste_Wilson
Member Posts: 532 EDU
A short exercise which creates the same part using both techniques.
https://cad.onshape.com/documents/c4beecf8b0667e99dda38486/w/5e1b8664a2f987e641d7f65d/e/fe55326887935609f3a8ac8f
Happy to attach a worksheet/ instructions word doc once I work out how...
Hi Pete,
Been running the Unit 10 for a couple of years now. Use reality server for the rendering section of learning outcome C
Happy to share resources as they take so long to produce!
http://www.pearltrees.com/t/fe-btec-engineering-new-spec/computer-design-engineering/id22235688
It's been really good. Students have appreciated being able to access it anywhere and that they don't have to worry about saving!
I think the fundamentals are the same as any 3D package...Sketch/ 3d/Sketch 3d/ repeat...but I've found not having to deal with software installs etc a massive help. All I need to do now is stop the college from continuing to have explorer as it's default browser
The share option is good for submitting projects, and the tracking is good to see if it's all their work.
