Why the size limit?
tony_459
Member Posts: 206 ✭✭✭
I tried to model a particularly large thing and couldn't because the dimensions were above a threshold. There must be a reason for the threshold, but just wondering why? I can model a scaled version of the thing, but if I export into third-party software, I'll have to get creative to scale it back up to its true dimensions. Would be nice to avoid this unnecessary step
Out of sheer curiosity, how big of an item were you trying to make?
What was the biggest dimension?
Earlier discussion here: https://forum.onshape.com/discussion/4316/maximum-dimensions
Apparently, this size limitation affects all the CAD systems that use parasolid.
And then, the height cannot be above 500 m:
Interesting. Thanks for the info
Feel free to add/vote for related improvement requests.
Thanks for that explanation - so the current limitation (1,000 m) is because it is 1e3 times the arbitrary (but very, very rational) selection of "m" as the base unit ?
I wonder if the "chip foundry", "architectural" or "city planner" versions of Onshape in the future could be built on different base units?
