How to identify/fix geometry issues with dxf imported models.
aaron_skidmoreaaron_skidmore Member Posts: 34 ✭✭
I am imported a DXF file containing font lettering into a sketch, then extruding. Most letter are ok, but some have issues. How can I find these issues.
The below link has some geometry issued with the 'e'
https://cad.onshape.com/documents/794ed360c1be4c356aeb08af/w/7230b0f2392f4e2d9134eacb/e/dad4a2272d2e68fea3c236b1
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,927 image
    Very odd - I drew a vertical line through the 'e' (which is a common method to find where/why sketches may be failing) and then it worked.
    splitting the curve fixed it.  No idea why.  I found it by moving the dividing line around that @NeilCooke suggested.
    www.accuratepattern.com
