Larger copy of entities
konrad_dawydiuk
Member Posts: 4 ✭
in Drawings
I have a project drawn from a photo . I would like to make a larger copy of the object as shown in the picture.
What's the best way to do it ? and how can such an irregular object be dimensioned ?
inside the sketch; scale can be found under transform.
Offset is also a sketch tool.
after you extrude the original sketch you could 'move face' the outside face also. But some of the sharp concave surfaces may cause an error.
Maybe a point map imported from a csv? then run transforms from the points??
