Symmetrical linear copy
scott_caskeyscott_caskey Member Posts: 53 PRO
Is there a way to create a linear copy symmetrically around the selected object/feature ?
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,985 image
    Only in Part Studios:
  • scott_caskeyscott_caskey Member Posts: 53 PRO
    What if it is not a feature, just a line or sketch component?
    No, it only works as a feature in a Part Studio, but not sketches or assemblies.
    Oh man... I need to make a pattern of lines centered around 1 line.  If I try to do two linear patterns one in one direction one the other, it won't recognize the second one from the same reference.
    edited July 2020
    Not sure what you mean here, but you can associate the distances by using the equal constraint like this:
    Or you could create 1 pattern and mirror.
