How do I mirror this feature?
chrisjh777chrisjh777 Member Posts: 209 ✭✭✭✭
I can't figure out how to mirror the chamfered face around the mid plane on this simple part.
https://cad.onshape.com/documents/a976d65ae8944393a7fed430/w/ba535ab73499417da3a764e9/e/9ff0540a7280430c96bf461d
    +1
  • chrisjh777chrisjh777 Member Posts: 209 ✭✭✭✭
    Thanks Guys.  Much appreciated.
    It would appear that in OS, you can mirror sketches or parts, but not features.  I think this calls for a "Feature" request to support, no pun intended!!
  • 3dcad3dcad Member, OS Professional, Mentor Posts: 2,482 PRO
    @chris_155  Feature mirror/pattern has already been marked as feature request. @lougallo can add you into that request.
    You can also mirror faces... (check a box and pick the faces to mirror)
     but at present there are stringent limitations on what faces can be mirrored, for instance, your chamfer "didn't make the cut", so to speak.
    Just to remember, face mirror has to be done within one part. Part studios easily make one forget that there is many parts involved.
    There is request also for multipart support for mirror/pattern features.
  • 3dexter3dexter Member Posts: 89 ✭✭✭
    +1
