How do I mirror this feature?
chrisjh777
chrisjh777 Posts: 211 ✭✭✭✭
I can't figure out how to mirror the chamfered face around the mid plane on this simple part.
https://cad.onshape.com/documents/a976d65ae8944393a7fed430/w/ba535ab73499417da3a764e9/e/9ff0540a7280430c96bf461d
  • andrew_troup
    andrew_troup Posts: 1,585 ✭✭✭✭✭
    +1
  • chrisjh777
    Thanks Guys.  Much appreciated.
    It would appear that in OS, you can mirror sketches or parts, but not features.  I think this calls for a "Feature" request to support, no pun intended!!
  • 3dcad
    3dcad Posts: 2,482 PRO
    @chris_155  Feature mirror/pattern has already been marked as feature request. @lougallo can add you into that request.
  • andrew_troup
    You can also mirror faces... (check a box and pick the faces to mirror)
     but at present there are stringent limitations on what faces can be mirrored, for instance, your chamfer "didn't make the cut", so to speak.
  • 3dcad
    Just to remember, face mirror has to be done within one part. Part studios easily make one forget that there is many parts involved.
    There is request also for multipart support for mirror/pattern features.
  • 3dexter
    3dexter Posts: 89 ✭✭✭
    +1
