Rotate extrude along sweep path axis! (wire rope)
Barry_van_WijkBarry_van_Wijk Member Posts: 46 PRO
Hi,
I have made a wire rope wich follow a spline/sweep function.
But the rope must twist along the sweep axis.
In a straight line I get it done with the helix function, but not with the bend (sp)line in the sweep function.
You can see in the example that i am using a FS to make a helix accros the sweeppath,
but that is not the way because it uses the helix path to sweep and not the origin sweep axis.
Anyone who can help?
Thank you!
Here my link!
https://cad.onshape.com/documents/6088391b27f54bc92a939687/w/9c2908d2bfa312418b5418e7/e/4a1390c7ab67553ca8f90f63
