Error when attempting to loft
jonathan_yu202
Member Posts: 9 ✭
Can you share your example with us as a public document? Thanks!
I'd start by splitting into quadrants to start
As a rule a solid loft does not handle profiles with inner loops. I'd like to see the case in which you made it work. Usually for design like this we recommend building solid first and then using shell feature to give it desired thickness.
