Flowing Tutorial and tangent constraint issue
 allen_stewart
                    Member Posts: 32 ✭
allen_stewart
                    Member Posts: 32 ✭
            Hello All,
I am new to Onshape and Im following the text tutorial and I am having a little problem with the tangent constraint feature.
I have the large circle connect to the small circle using two lines. As soon as I add the tangent constraints (like the tutorial shows) both circles become the same size. Im guessing im doing something wrong but Im following the tutorial exactly step by step.
https://cad.onshape.com/help/#tutorial-sketch.htm%3FTocPath%3DTutorial%7C_____2
Thank you
             3dcad
                            Member, OS Professional, Mentor Posts: 2,476 PRO
                    Try dimensioning circles first, resize might be because of Onshape trying to scale things for you.. 3dcad
 Onshape has a functions that allows you to draw a sketch with 'free hand' and when you add the first dimension, it will scale the rest of the sketch accordingly. This is sometimes very helpful, some times a bit annoying - but the important thing is to know it will do this everytime.//rami5
In either case, establishing tangency with two circles would then force those circles to be the same diameter.
To find out if they're constrained, edit the sketch, and tick the box for "show constraints"
Going through the tutorial a third time and dimensioning the circles first appears to work.
Looks to me like the tutorial needs to be updated.
