How to copy folder?
ehsan_pazookiehsan_pazooki Member Posts: 52
Hello Guys,
a little question! How can I copy a folder in Onshape? Is there any way?
regards,
Ehsan
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,926 image
    edited August 2020
    Folders cannot be copied - that includes folders on the documents page and folders within a document. If you're using Enterprise, you can clone a project (which is essentially a folder).
  • ehsan_pazookiehsan_pazooki Member Posts: 52
    @NeilCooke
    Hi, thank you for your answer. How can I clone a project ?
    Regards
    Ehsan
    edited August 2020
    If you don't see project icons like this on your documents page then you're not using Onshape Enterprise:
    If you do, right-click and select Clone Project
    EDIT: actually that wouldn't help you anyway because that just clones the project users and permissions, not the contents.
