Importing image when "Import" icon is hidden
ralph_stirlingralph_stirling Member Posts: 7 EDU
In my browser (FF) on my laptop (Dell E6430), the document tab bar covers up the bottom portion of popup dialogs, such as the "place image" dialog in drawings.  I need to import a png image, but the import icon is covered up.  Tabbing and enter does not seem to activate it either.  Is there any way to either toggle the document tab bar or otherwise get at the import icon?
Thanks,
-- Ralph
    edited August 2020
    The only way you can do this is to either scale FF from the menu top right or change the screen resolution (if you can)
  • ralph_stirlingralph_stirling Member Posts: 7 EDU
    Scaling 80% did it!  I hadn't thought of that.  Thanks again.
    -- Ralph
