Derived Component Feature / Body As A Work Surface?
john_hammons643
Member Posts: 17 EDU
in General
Hello! I'm new to Onshape and was wondering if Onshape has the feature that allows deriving a "body as a work surface" from a derived component similar to how Autodesk Inventor does it? Any tutorial or link that offers instruction on how to use this feature (if it exists) would be helpful!
Thank you!
Thank you!
https://cad.onshape.com/help/Content/derived.htm?Highlight=derived
I’ve never used Inventor. I’m curious about that term ‘Body as a Work Surface’. Could you explain what ‘body as a work surface’ is or what it does or how it works
I'm also not sure exactly what "Body as a work surface" is supposed to do. If you could describe how its used, I'm guessing there is an alternative workflow that can accomplish something similar. It looks like you've been able to derive things. Something else worth looking into is "in-context design". That allows you to create an assembly, then create a new part studio where you can design parts that reference the assembly.
https://www.youtube.com/watch?v=xSDHWuIJ7xw&t=2s
You could work in the same part studio as the original boat, or derive the whole boat into a new part studio. Then, you can select individual faces, use "thicken" to get a new body for a single panel, apply a material to the new panel, and then you can view the mass properties for that single panel.
If you really the individual surfaces as an intermediate step, you can select a face, use the "offset surface" tool to create a new surface, but just set the offset distance to zero. Then you have a new surface coincident with the model that you can thicken/manipulate just like in your video.
Now comes the fun (sarc) part of the competition....using Simpson's Rule!
