Variables and driver/ driven dimensions
Ste_Wilson
Member Posts: 550 EDU
So I've been playing with funicular polygon sketches and it would be amazing if I could take the dimensions from the diagram which are all dependent on the F1 and F2 and display these.
https://cad.onshape.com/documents/30632144ce1febd02d23f53f/w/279fa6d817d5712f10a41d7a/e/758d3241e9b203083846ed97
I can set a dimension to be driven by a variable, I like this!
Can I then get dimensions dependant on those variables to display anywhere/to appear in a table?
Is this feature script territory?
john_mcclary
Member, Developers Posts: 4,029 PRO
You can use 'equal' constraints, but they will measure the length of the object relative to the sketch plane you are projecting to. So only works if they are on the same parallel plane.
Unfortunately there is no built-in ability to 'link' dimensions.
Measure value is a good feature to use here
https://cad.onshape.com/documents/77baa8153589a7fc5f289829/v/ceb4a03e4ac77173bf6d0074/e/181cb871f3008e6b885df46a
5 -
john_mcclary
No way to extract it to a table, but they do create variables.
So you can do a lot with them once they are created, including importing them into other part studios/documents5
So there is no way plonk that into a dynamic table/ spreadsheet type thing?
But thanks, that's really helpful!
I can use that this now as an example for my students on how to graphically analyse a simple frame!
Putting the 'fun' in funicular!
You could create a custom table and read all of the variables from the part studio, then export that table however you want
here is some sample code for a custom table you can copy and experiment with
https://cad.onshape.com/documents/ae128fca39a1d825a3c5d427/v/c5a2dfaa44fa712f8445f53f/e/3068316aed3ce312a6d15462
