Extrude remove not possible.
hank_debeyhank_debey Member Posts: 28 ✭✭
I am a learner.
I have an extruded rectangle with a thickness of 10mm. When I attempt to do an "extrude remove", to create a hole, the hole is not created.  There are black circles on both sides of the rectangle but no hole. I can do an "extrude add" as shown below.
If I select the rectangle, a strange pattern is displayed. I don't get that pattern with other parts in my document. Does anyone know
1) what the pattern signifies
2) what I can do to extrude a hole?
    You may have two parts there.  Try hiding the orange part.
    And sharing public doc as @alnis_smidchens mentioned is best for getting specific answers.
    www.accuratepattern.com
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,878
    I think you nailed it there.
  • alnisalnis Member, Developers Posts: 452 EDU
    @hank_debey I use a tool called Peek. Unfortunately, it's only available on GNU/Linux as far as I know. My main machine is a System76 Lemur Pro running Pop!_OS, so Peek is great for my use case, but I don't think there's a Windows or macOS version. It can record gifs, webms, mp4s, and apngs. Quick video showing how it works:
    https://youtu.be/jcwMvY944c8
    For longer screen recordings, ones needing higher framerates or resolutions, or ones that need sound/a voiceover, I use OBS Studio (Open Broadcaster Software Studio): https://obsproject.com/
    It's free and open-source, and runs well on Windows, macOS, and Linux, but doesn't have a gif output (at least I can't find one), so you would have to run it through a converter if you want a gif. It's a very powerful and popular program, but might be overkill for a quick tutorial gif.
    Hope this helped!
    Looks like some sort of graphics error. What browser are you using? Is it up to date?
    @hank_debey can you share a public link to your document?
  • hank_debeyhank_debey Member Posts: 28 ✭✭
    That was qucik. Here is the link to the document. https://cad.onshape.com/documents/662cdddd47db3356a46031cb/w/5328a671f81c386727127ab1/e/b875b98ff3b764a9ef3112ce
    I hope that is sufficient. I didn't see any setting to change but if there is something else I need to do to share it, let me know.
    I am using a Chromebook so the browser is Chrome and a Chrome OS update happened a few days ago.
    One of the things I wondered about was a part inside of a part. I will look again but I don't think so. This part was the sixth part I made in the design process so I was still in the early part of learning OnShape.
    Yes, it was a part inside of a part. I thought I had checked that but I checked again and voila, I am back on the road again. Thank you.
    alnis_smidchens the animated gif you sent was very helpful. How did you make it?
    Hope this helped!
    Thanks for this great information. In our workshop and training center, we use Chromebooks, hence our appreciation for OnShape. We do have one Chromebook with Ubuntu installed so I will use it to look into Peek.
