Extrude remove not possible.
I am a learner.
I have an extruded rectangle with a thickness of 10mm. When I attempt to do an "extrude remove", to create a hole, the hole is not created. There are black circles on both sides of the rectangle but no hole. I can do an "extrude add" as shown below.
If I select the rectangle, a strange pattern is displayed. I don't get that pattern with other parts in my document. Does anyone know
1) what the pattern signifies
2) what I can do to extrude a hole?
bruce_williams Member, Developers Posts: 842 EDU
You may have two parts there. Try hiding the orange part.
And sharing public doc as @alnis_smidchens mentioned is best for getting specific answers.
www.accuratepattern.com1 -
NeilCooke Moderator, Onshape Employees Posts: 5,878
bruce_williams said:You may have two parts there. Try hiding the orange part.
And sharing public doc as @alnis_smidchens mentioned is best for getting specific answers.Senior Director, Technical Services, EMEA1 -
alnis Member, Developers Posts: 452 EDU
Edit: oops, I didn't see there was an accepted answer already, sorry!
Which part are you trying to add a hole to? I'm not sure if I found the right thing, but it looks like you have three identical parts in the same spot, so your screenshot might be of a hole through one part but with the other parts still present:
In any case, if you're just starting out, I strongly recommend doing some of the tutorials at learn.onshape.com before you jump into bigger projects:
Introduction to CADGet in touch: contact@alnis.dev | My personal site: https://alnis.dev
@alnis is my personal account. @alnis_ptc is my official PTC account.5 -
@hank_debey I use a tool called Peek. Unfortunately, it's only available on GNU/Linux as far as I know. My main machine is a System76 Lemur Pro running Pop!_OS, so Peek is great for my use case, but I don't think there's a Windows or macOS version. It can record gifs, webms, mp4s, and apngs. Quick video showing how it works:https://youtu.be/jcwMvY944c8
For longer screen recordings, ones needing higher framerates or resolutions, or ones that need sound/a voiceover, I use OBS Studio (Open Broadcaster Software Studio): https://obsproject.com/
It's free and open-source, and runs well on Windows, macOS, and Linux, but doesn't have a gif output (at least I can't find one), so you would have to run it through a converter if you want a gif. It's a very powerful and popular program, but might be overkill for a quick tutorial gif.
Hope this helped!Get in touch: contact@alnis.dev | My personal site: https://alnis.dev
@alnis is my personal account. @alnis_ptc is my official PTC account.1
I hope that is sufficient. I didn't see any setting to change but if there is something else I need to do to share it, let me know.
One of the things I wondered about was a part inside of a part. I will look again but I don't think so. This part was the sixth part I made in the design process so I was still in the early part of learning OnShape.
Introduction to CAD
Hope this helped!
