Disrupted Internet Connection / Hard-Boot-Logout?
matthew_stacy
                    Member Posts: 489 PRO
                                  in General
                    Onshape periodically locks up on me trying to reload a model.  I believe the root cause is momentary loss of internet connectivity on my end.  If I logout and log back in the result is that multiple clones of myself are logged into the document simultaneously as shown in the attached photo.
I'm starting to feel a bit schizophrenic over here.  Is there any way for me to trigger a hard reset to release myself from a document?
The duplicate users will disappear when the session times out after 10 minutes.
@Cristopher_Bowers
Please submit a support ticket from inside the document so we can help diagnose the issue!
Onshape, Inc.
Those other instances of "you" are not preventing you from continuing to work, are they? If they're in a drawing, you can simply say "open here instead" (or whatever the message is)...if a Part Studio or Assembly, there's no problem with multiple users...
Are you running into issues where you can't keep working and allow them to timeout naturally?
