Split Feature - Missing Item
Julien_SJulien_S Member, csevp Posts: 3 PRO
After splitting the wing bellow in the Y axis, the boolean unite operation does not work, the bottom part of the wing shows up as "missing item".
Any ideas of how to solve this issue?
  • lanalana Onshape Employees Posts: 752 image
    @Julien_S
    Please file a bug using "?" menu.
  • Jacob_CorderJacob_Corder Member Posts: 140 PRO
    This was supposed to be fixed in 1.119 per the change log. I hope this is an isolated occurrence.
    1. Fixed a specific issue where edges of part show as “Missing item”
  • billy2billy2 Member, OS Professional, Mentor, Developers, User Group Leader Posts: 2,117 PRO
    You could try and extrude your split tool and create a surface to split which intersects your target in one location. I don't think you need boolean.
    Split with sketch is uncontrollable:
    Surface to surface split is more controllable:
    I don't believe you should be boolean an unwanted split:
