Make standard Isometric View the same for Part studio/assembly and drawing
Josef_SnabbJosef_Snabb Member Posts: 2
edited October 2020 in Drawings
Hello.
I realized this when I was making exploded view for assembly. When you choose Isometric view in assembly, and then insert Isometric view on drawing it is mirrored.
Of course an easy work around is to first create a 2D view and then make a projected view to match the Isometric view of the assembly, but why are the standard Isometric views not the same? This could be a small improvement. In other CAD softwares (like Solidworks) the isometric view are the same as standard between 3D and Drawing. .
Best Regards
Josef Snabb
  • lougallolougallo Member, Moderator, Onshape Employees, Developers, csevp, pcbaevp Posts: 2,014
    @Josef_Snabb This is the difference for first vs third angle. Mine are the same at 3rd angle.  What is your drawing set to?
  • Adam_MichaAdam_Micha Member Posts: 17 ✭✭✭
    I work at the same company and we use first angle projection.
