https://cad.onshape.com/documents/5cddc0403081dcbb2a5e23a3/w/7a01cc8eee72c0a36869a156/e/9beeff4abaa90baae9e01043
I have made it public.
The first step to creating the belt is to insert both pulleys into an assembly. The pulleys can be positioned and mated in place. You can also make a layout sketch in a new part studio, and insert the sketch into the assembly to use as a reference.
Next, I created a new part in context. This is done from within the assembly. Next, I used the belt custom feature to create the belt.
Last step, I inserted the new part into the assembly.
For more information on in-context, take a look at the top down design course in the learning center. Let us know how you make out!
Onshape Document
https://cad.onshape.com/documents/77550143a68d7f8790e8528b/w/04b7beed8a99dbd70a33491f/e/d4d27d0533a8adfd89dbd676
Onshape Learning Center
https://learn.onshape.com/learn/course/managed-in-context-design/what-is-top-down-design/what-is-top-down-design
Can you please explain how to create new part in context and how to use belt custom feature, that you mentioned above in 2nd step.
Thank you for your valuable time.
