Hello, how to display the surface area of this section?
in Drawings
Hello,
This seems impossible by the mass properties because it only takes into account the parts
NeilCooke Moderator, Onshape Employees Posts: 5,886
You can either:- Use the Split feature to cut the part in half with a plane (or similar), or
- Create a sketch on a plane and use the Intersect entity to create a fully enclosed sketch face.
Senior Director, Technical Services, EMEA6
Both option will create a planar face that you can select and the area will be displayed in the bottom right corner.
