custom properties
JonvollmerJonvollmer Member Posts: 2 PRO
Sorry if this has been asked before.. new to Onshape.  I found a feature script Measure Value #1188 that I would like to link the result to a custom property. Can this be done and if so, could you please explain how to do it.  Thanks,  Jon
  • alan_baljeualan_baljeu Member, User Group Leader Posts: 111 ✭✭
    I believe it can be done, but might involve some editing of the featurescript.  I don't know how to find Measure Value.  Measure Distance assigns a variable and you can use that variable in OnShape.
    What kind of property are you trying to assign?  A part property?
    Creating knowledge-driven design automation software, for molds, etc.
    www.virtualmold.com
    You can use set custom property then use the variable created by measure value.
    https://cad.onshape.com/documents/11eb3fc7b01f4997e5318a6f/w/49252498f47d8a706baf2f54/e/675f33b3c1587cc12c20e6fc
  • JonvollmerJonvollmer Member Posts: 2 PRO
    Thank you for the replies,  I managed to get the above working except I can't seem to get the result to appear in my custom property.  I have created one for Cut Length that I would like to transfer to my BOM.
    Sorry, looks like I had a bug, It should be fixed now
    I'm trying to understand what you presented John.  I see the feature scripts and they run, but where do I as a user get access to the properties you set here in this example?
    www.virtualmold.com
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,847
    @alan_baljeu - those are custom properties that can only be created with a Professional account
    edited October 2020
    Thank you Neil.  I need to learn about this more.  Can you direct me?
    Besides the question of learning this feature, I just checked, my account is "Partner".  Does this include Pro features or do I need to upgrade?
    www.virtualmold.com
    I would think so? If you have an entry called custom properties in your company settings then you're good.
    Yes I have this.  Now, how can I view the custom properties in the above document?
    www.virtualmold.com
    Custom properties are unique to a company. In John’s code you’ll see id numbers for the custom props. You can find this by creating/ editing the custom prop in company settings.
    Thanks very much john
    www.virtualmold.com
  • Calum_DoigCalum_Doig Member Posts: 1 PRO
    Is there a way of getting this to read from composite parts and assemblies?
    Featurescripts operate in part studios which can have composite parts. Assemblies do not support featurescript. You can add custom properties to assemblies but “read from” can’t be automated. Now if you just mean to draw the properties into a BOM, I expect you can achieve your goal.
    www.virtualmold.com
