Trouble combing two thickened lofts
in General
This is for an extension to a cycle mudguard at https://cad.onshape.com/documents/655fb46210eab35462ca6602/w/dd720d6171433626b1d8aa2a/e/00661d304889002974745606.
I have lofted two surfaces and thickened them to create two parts but however I choose to combine the two they will not join and I get red warning lines crossing both parts. The first image below shows the two parts seperate, the second shows what comes up during a boolean union.
One of the parts is generated from sketches 1-3, the other from sketches 3a-4. Sketch 3a Uses parts of sketch3 but is formed on it's own plane that is on the face of plane 3. In fact I have tried various combination of using faces or planes on which to base sketch3a but always with the same result. Since the problem is on only one side the cause should be obvious, but I just cannot see it
Help in pointing out what is probably blindingly obvious would be appreciated.
You have a few options:
My solution:
https://cad.onshape.com/documents/0cc3fe4007791d7bdcd16361/w/1f356037844b053a00633685/e/0a5e2b6143d12ad315558b9b
Hope this helps!
I see that NX download! don't deny it!
Done it:
- Onshape - went pretty smoothly
- Inventor - barely scraped by, I had to use some workarounds to get a loft to work that involved lots of manual clicking
- Solidworks - also went pretty smoothly especially considering how I've only recently really gotten into SW
Attempted but failed:
- Fusion 360 - I couldn't get it to cooperate even after trying a bunch of different methods, threw errors for valid loft setups
Remaining to try:
- NX
- Creo
- BricsCAD
- Solid Edge
- IronCAD
- FreeCAD
Ones I probably won't do:
- CATIA - no free student version (I did actually pay for the SolidWorks student license so that I can be prepared for any SW stuff in university)
- Microstation - It looks like quite the process to get a student version, including having my school contact them. I will probably spend more time trying to get a license than I will modeling this part.
If anyone has suggestions for other CAD software I should check out, please let me know! Also, here is the part I'm modeling:
Cool project! I hope you're making it into a video.
@going_along
I didn't mean to hi-jack your thread. Were you able to get your question answered? I'm glad to take a look if not.
