Importing an OBJ file to an assembly
Hello, I am having trouble importing an OBJ file, the file will import as its own tab however I see no way to get it into the assembly. Is there anything I can do to fix this?
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,932 image
    Can’t use meshes in assemblies. They are for use as a reference when modelling.
  • Maximillian_BaloghMaximillian_Balogh Member Posts: 3
    Is there any way that I can import it to a parts studio, I would like to use it as a reference but I can not take it out of its own tab.
    Yes - right click the tab at the bottom and select import.
    @Maximillian_Balogh
    If you mean that you can see it imported, but it's in its own Part Studio, you can derive it into other Part Studios using the Derived feature:
    https://cad.onshape.com/help/Content/derived.htm
