Folding paper or cardboard into a rounded shape
in Drawings
Hi all,
Usually I fold cardboard using the rotate feature with each extrusion.
This is the easiest way I have found when the folds are straight.
https://cad.onshape.com/documents/9868b15118620477878e9ba8/w/6b182f1d99f44145e27058e2/e/17bce658314676f33e3ca108
There I am stuck because the folds are rounded and the cardboard must warp like in the photo in the file.
https://cad.onshape.com/documents/f9d844de4dda81f7481009fd/w/0ede7447e19d51a8d558e1a8/e/a14c380f6703c2798b529efe
Thanks for your feedback,
Denis.
Denis.
I do not understand.
Or you forgot to put a link ...
Thanks for your feedback.
You may need to put a slight flat on each end point where the red and blue meet.
Hi,
I can't do it :(
I created a "sketch 3" with a curve that can serve as a guide, but that doesn't change anything .....
is this perhaps what you're going for? (Link). if this is something you're planning to do more of, you should explore the sheet metal tools, which can also produce a flat pattern for you. I've designed packaging with it before.
Independent Onshape Consultant | Industrial Designer
I added a super quick sheet metal example to the same link above, in case that's of interest.
I think this is a curved bend of the type that is common in the bottom of french fry containers, so is something like this:
This is really just a simulation of what this part would be like in its "folded" state - with the curved fold, Onshape can't treat this like sheet metal, and won't be able to give you a flat pattern. Here's a way to simulate the flat pattern by using the Measure Value custom feature script to get the length of the folded flap - then use that value (as a variable) to correctly size the flattened flap:
You can see how it's built here: https://cad.onshape.com/documents/1af71d2dd62160be757d3243/w/ec0b5df8025976633d7559fc/e/d0a0192b9407121b702af599
Another very useful Custom FS in this model is the MultiMirror FS, made by @Evan_Reese .
Good luck!
Romeo
Hi,
Thank you all for your help...
Now I have to understand how you did it.
Denis
How to select all "Edges of Sketch 1" in "Split" ?!
When I select with a window, it adds each segment in the list and not just a group of segments.
And the result is bad.
Evan's "Split" model
Or how to put a Sketch on a rounded surface ?!
it could be easier ...
@macdony_denis select the sketch from the feature tree itself, and Onshape will sort it out.
There's no way to have a "curved sketch" but for most situations either using split on a surface like this, or using projected curve can get you what you need
Thank you very much Evan, I will look again 😉
I succeeded with 8 "Transform" but the folds are not very beautiful 🙄
I'm curious, what's your final purpose? Are you manufacturing these? if so, just 1, or 1000? or is it for renderings, or 3D printing, or something else completely? The goal can inform modeling decisions a lot.
This is for the renderings.
