What are assembly Items?
alan_baljeualan_baljeu Member, User Group Leader Posts: 111 ✭✭
It always shows > Items (0) in every example I've seen.    What is this for?
Creating knowledge-driven design automation software, for molds, etc.
www.virtualmold.com
    @jakeramsley - what does "applied to instances" do exactly? It sounds like you're referring to the "reference" input option when adding an item. I've seen this option when adding items to an assembly, but can't figure out what it does or why I would want to do it. Does it change something in the BOM? Drawings? Properties?
    I think reference is for future use. I think I heard something about allowing ballooning or something. Doesn't seem to do much now
    @john_mcclary - That's what I expected, but I've seen it come up a couple times here with no explanation, so I've been left wondering if everybody else knows something that I don't know.
  • TimRiceTimRice Member, Moderator, Onshape Employees Posts: 315
    edited October 2020
    Items allow you to reference a specific face on a part and currently we do not support any note/callout/balloon references to faces in drawings. If you do apply the reference now then you will be well setup to take advantage in the future when/if we release tagging on faces in drawings :smile:
    Onshape, Inc.
    That's what I thought I remembered. But I don't feel comfortable applying settings until I 've seen them in action. So I'll continue ignoring this option for now  :)
